When I try to paste a URL, clicking on the Create button “does nothing” as can be seen in the attached video. Selecting one of the “formats” leads to the URL being pasted into the text. Maybe I am just misunderstanding the purpose of the “Create” button.
Hi Patrick,
Thanks for the report!
Yes, it is a bug, where the button handler is not implemented properly.
I can’t believe why I couldn’t notice that while testing beta ![]()
Instead, you can use arrow keys to select and hit Enter to insert the link.
I’ll remove the ‘Cance’ and ‘Create’ buttons in the next release.
The ‘Cancel’ and ‘Create’ buttons have been removed in v5.8.1. For more details:
Thanks again for the feedback!
