The page editor/rendering is not resizing.
Troubleshooting steps taken
restart inkdrop
quit inkdrop
brew rm inkdrop
rm -rf ~/Library/Application\ Support/inkdrop
brew install inkdrop
disconnect macbook from external displays and repeat steps listed above
Console output
Macbook model information
Other details
I have never encountered this issue on other macbooks which are newer models. This macbook is unable to support 2 external displays without a pluggable USB-C hub and DisplayLink installed.
I use Ansible to set up my Macbook, which includes installing and configuring Inkdrop. You can review the automated steps here
Device: Macbook Pro 13-inch, M1, 2020
Platform: MacOS
Platform version: Sonoma/v14.4.1
App Version: 5.8.0
How to reproduce the issue
Run Ansible playbook to install and configure inkdrop
mkdir ~/temp/
git clone https://github.com/lowranceworks/macbook-config.git ~/temp/macbook-config
cd ~/temp/macbook-config
ansible-playbook ./restore.yaml --tags inkdrop
Launch inkdrop
I am able to recreate the issue with no errors in the console.
q1701
(q1701)
April 13, 2024, 6:11am
3
I am also facing the same problem.
It seems that this behavior started with version 5.8.0.
I am using the Windows version.
Lukas
April 13, 2024, 11:05am
so with “editor is not resizing” you are referring to the red marked areas? (see the attached image below)
or am I misunderstanding you?
This is a new feature that was added in v5.8.0.
For more information and how to disable this behavior, see the announcement of v5.8.0
Also there are a few other post regarding this:
I have checked the troubleshooting
The editor view seems incorrectly when upgrade to new version 5.8.0
[image]
Platform: macOS
Platform version: Sonoma 14.3.1 →
App Version: 5.8.0
[image]
There is a weird padding after the update - is there a config to change that?
On the editor screen.
Immediately after I updated Inkdrop to version 5.8.0, margins were always displayed on the left and right sides. Is there a way to make this blank like before?
The part circled in red.
[スクリーンショット 2024-04-03 17.13.55]
-Platform: macOS
-Platform 13.6.3
App Version: 5.8.0
The symptoms occur on both new and existing notes.
It’s a feature, not a bug! … Thank you, Lukas.
April 16, 2024, 2:14am
6
Sorry for the confusion guys
May 1, 2024, 2:35am
7
The ‘Readable line length ’ option has been disabled by default as of v5.8.1.
Please check out here for more details:
[2024-04-30_Inkdrop Desktop v5.8.1_thumb-play]
Hey Inkdroppers,
Thanks for all the feedback after the release of v5.8.0 and during the beta testing! It’s got much stabler.
Bug fixes
The ‘Readable line length’ option has been disabled by default
The ‘Readable line length’ option was introduced on v5.8.0 . But, this option made the existing users so confused as they reported on the forum (1 , 2 , 3 , 4 , 5 ). Then, Shimizu-san suggested that it’d be nice not to enable this option by default a…
Thanks again for the feedback!
