Platform:
Platform version:
App Version:
When writing or editing notes the layout of the editor seems to be broken. It no longer uses the whole screen space for the note (only partial part of the space). See screen shot.
Macbook Pro M1Max MacOS 13.6.3 Ventura
Inkdrop version 5.8.0
No plugins installed
              Hi!
Please look at this issue.
    [image]
There is a weird padding after the update - is there a config to change that?
                    May 1, 2024,  2:34am
              3
              The ‘Readable line length ’ option has been disabled by default as of v5.8.1.
Please check out here for more details:
    [2024-04-30_Inkdrop Desktop v5.8.1_thumb-play]
Hey Inkdroppers,
Thanks for all the feedback after the release of v5.8.0 and during the beta testing! It’s got much stabler.
 Bug fixes
  The ‘Readable line length’ option has been disabled by default
The ‘Readable line length’ option was introduced on v5.8.0 . But, this option made the existing users so confused as they reported on the forum (1 , 2 , 3 , 4 , 5 ). Then, Shimizu-san suggested  that it’d be nice not to enable this option by default a…
Thanks again for the feedback!
