Download here!
New features
- Auto update: Support disabling auto update and checking for update manually from the application menu (Thanks Sceptic)
- Command: Support opening new note in separate window (Thanks Ryuki)
core:new-note-in-separate-window/ cmd-shift-n on macOS, ctrl-shift-n on Linux and Windows
Bugfixes
- All platforms: The app randomly crashes (Thanks Phil, Aleksis, and Dmitry)
- Bumped up Electron from 16 to 21
- Markdown Preview: Empty links cause the app to exit (Thanks James)
- Security: Prevent potential OS injections through the Markdown preview
- Do not allow
iframeHTML tags by default. You can enable it back from the preview settings. Only https URLs are allowed. - Prohibit
webviewandobjectHTML tags.
- Do not allow
- UI: Some icon colors are incorrect
- Note list: It causes a note conflict when pinning quickly (Thanks Dmitry)
