Inkdrop Desktop v5.8.1-beta.2
Hey Inkdroppers,
Thanks for helping me make the app stable!
Bugfixes
  • Editor: Custom font family not being applied (Thanks Shimizu-san)
  • dev-tools: Copy tag id from sidebar throws an error (Thanks Lukas)
  • Preferences: Do not enable the Readable Line Length option by default (Thanks Shimizu-san)
Improvements
  • Avoid triggering Auto link title when the cursor is in the middle of the link
    • For example, when you type
      [link title](|
      (| is the cursor position) and hit Cmd/Ctrl-V, it shouldn’t trigger the paste-as-link dialog.
Internal changes
Adopting Cascade Layers
Cascade layers would make theming much simpler.
They allow themes to avoid rule specificity issues.
Inkdrop will bundle more default styles in the future versions, and with cascade layers, custom themes will only need to override the default styles rather than including every style.
UI, syntax, and preview themes are automatically enclosed with the corresponding cascade layer in v5.8.1.
The order of precedence is defined as the following at the moment:
@layer reset, base, tokens, theme, theme.ui, theme.preview, theme.syntax;
  • reset: Reset styles
  • base: The app base styles
  • tokens: CSS common variables
  • theme.ui: UI theme
  • theme.preview: Preview theme
  • theme.syntax: Syntax theme
Others
  • Remove the reset CSS styles from UI theme stylesheets automatically when loading
  • :bug: Focus rings not working on some components
    • Changed the cascading layer to @layer theme.ui
Previous changes
