Nested Detail View
I love the detail view, but I would really like to see this feature extended to nested notebooks. As an example, if I have a top-level notebook “Development” with nested notebooks “JS” and “Python”. From the top-level I can see the “Detail” of all notebooks. But, if I view the detail of “Development” I’m not able to view the detail of the JS or Python notebooks, I have to navigate back to the top-level and then view the detail of the specific folder I want.
Hi Tim,
Thanks for the suggestion.
It sounds like an issue with how you organize your notes.
The workspace view (detailed view) is basically for viewing a project/workspace.
“JS” and “Python” sound like tags rather than projects.
Why would you want them to be notebooks?
I guess you are learning those languages. If so, the project should be “Learning” or something with the language tags.
It’s been supported in the new mobile app (beta)
It is now supported in v5.6.0-beta.1.
