Is there a plan to add a feature to display line breaks as <br> in the mobile
in the mobile version of the preview?
This feature was available in previous versions, and I would like it to be added again.
mobile 版の preview で改行を br で表示する機能追加予定は有りますか。
以前のバージョンにはあったので追加を希望します。
Hi Shimizu-san,
Plugin support is currently being considered. That’s an ideal plan though, it’d be ok to add an option for line breaks without needing spaces meanwhile.
I am looking forward to the plugin functionality, but at the moment, I would like an on/off feature.
This is because, on small-screen mobile devices such as iPhones, html display is often easier to read, as line breaks are merged making it difficult to read, and it is often necessary to switch between editing mode.
Please consider it.
plugin 機能に期待していますが、現時点では onoff 機能が欲しいです。
iPhone などの画面の小さいモバイル端末では html 表示の方が見やすいことが多く、改行が連結されて見辛くなって編集モードと切り替えながら使うことが多いためです。
検討をお願いします
Thanks for clarifying your background. That makes sense.
It is supported in v5.3.0-beta.1. Can you try it?
Does iOS’s TestFlight requrie a code?
ooops, I shared a wrong URL.
Can you try this URL?
https://testflight.apple.com/join/zU5AuFU4
I was able to obtain the beta version!
Now officially landed in v5.3.0. Thanks again for reporting!
