Inkdrop Mobile v5.3.0 beta.1 is out!
  • Android build 96
  • iOS build 122
:bell: Markdown Alerts syntax support
Recently, the desktop version supported GitHub-flavored Alerts. It is a simple extension of Markdown, which allows you to insert ‘alerts’ a.k.a. admonitions or callouts. Now it is also available on the mobile version. For example:
> [!IMPORTANT]
> This is currently a work in progress, expect things to be broken!
:wrench: New Markdown renderer option: Newline to break
With this option enabled, you can have hard line breaks without needing two white spaces at the end of lines.
Thanks Shimizu-san
:smiling_face_with_sunglasses: e-Ink tablets support
I finally found what blocked the app to support e-Ink tablets in AndroidManifest.json :joy::+1:
Now you can install the app on e-Ink devices like BOOX Note Air 2!
:laughing: Join beta testing
Here!
