Inkdrop Mobile v5.3.0
Hello, it’s Takuya.
I’m happy to announce that Inkdrop for mobile v5.3.0 is now available!
:bellhop_bell: Markdown Alerts syntax support
Recently, the desktop version supported GitHub-flavored Alerts. It is a simple extension of Markdown, which allows you to insert ‘alerts’ a.k.a. admonitions or callouts. Now it is also available on the mobile version. For example:
> [!IMPORTANT]
> This is currently a work in progress, expect things to be broken!
simulatorscreenshot4509C892-8E57-4E4A-B2D2-B2D231D2BD0A
:wrench: New Markdown renderer option: Newline to break
With this option enabled, you can have hard line breaks without needing two white spaces at the end of lines.
Simulator Screenshot - iPhone 15 Pro - 2024-07-16 at 14.42.43
Thanks Shimizu-san
:smiling_face_with_sunglasses: e-Ink tablets support
I finally found what blocked the app to support e-Ink tablets in AndroidManifest.json! :joy::+1:
Now you can install the app on e-Ink devices like BOOX Note Air 2!
:lady_beetle: Bug fixes
https://my.inkdrop.app/download/
