Inkdrop Desktop v5.9.0-beta.2
:light_bulb: Previous release:
This binary would be a release candidate for v5.9.0!
Improvements
  • feat(export): allow raw HTML in “Copy as Simple HTML” (Thanks fuyuton)
  • fix(mde): use --primary-color for fat-cursor-color
Bugfixes
  • fix(note-tags-bar-input): randomly causes duplicate notes when moving focus
  • fix(theme): custom drag layer content notes has wrong colors
  • fix(theme): better visibility for vertical and dropdown menus, and metadata section on preview
  • fix(theme): add variables for kbd
  • fix(preview): avoid applying the default codemirror syntax theme to the preview inline codeblocks
  • fix(macos): revert titleBarStyle to hidden
  • chore(dep): bump up codemirror
  • feat(theme): add css variables for notification view
  • fix(app): deactivate plugins when destroying the instance
  • fix(theme): explicitly specify color-scheme
  • fix(theme): add variables for notification views on sidebar
Theme deprecations
Themes no longer maintained by the author are flagged as deprecated in the app.
  • banana-dark-ui
  • monokai-dark-ui
  • material-palenight-ui
  • octopus-dark-ui
  • material-ocean-ui
  • horizon-dark-ui
Join the beta testing :raising_hands:
Note: Login required
Thank you for your feedback, as always​:heart:
