Inkdrop Desktop v5.6.2-beta.0
Hey Inkdroppers,
Thank you for testing the beta version and reporting issues!
Bug fixes
  • fix(note-list): The popup menu for opening notebook not working (Thanks Shogo-san)
  • fix(keymap): Canceling multi-stroke keymaps not working (Thanks Markus)
  • fix(editor): “Move to notebook” not working properly, where it randomly moves a previously opened note (Thanks Shimizu-san)
  • fix(editor): Do not transform HTML into Markdown when pasting if it has special markups (Thanks Jake and Lukas)
Improvement
  • chore(electron): Bump up to 25.9.5
