Import Markdown gives blank characters in dialog box
I’m brand new to Inkdrop (coming from Bear). I want to import my markdown notes (or direct from Bear if possible). Using the app on my Manjaro laptop, I clicked the File > Import > from Markdown files …
After selecting the notebook, I get a dialog box that I assume is for selecting the file. However, all of the text is missing, replaced by empty boxes. I’m assuming this means a font availability error but don’t know how to fix it if it is on my end. I’m assuming its an app or plugin error.
If this is a noob error, please forgive me.
  • Platform: Manjaro
  • Platform version: 4.14.199-1-MANJARO
  • App Version: 5.1.1
select Notebook
dialog box to select file … error here.
Hi Rich,
Thank you for reporting it.
It looks like a similar issue with this, please check out:
It is an Electron’s issue but a workaround is not found at the moment, unfortunately.
I verified my locale and it shows en_US.utf8.
Apparently this is an issue across a variety of apps on Linux (irrelevant of the flavor) if Electron is part of the mix. I haven’t found a solution.
I ended up borrowing a Windows PC for a bit, installing Inkdrop and copying in the files. I have a lot more to copy but at least this approach is easier than individually copying each note.
Check the linked thread, I just posted how I managed to fix it there.
Solution:
