Love inkdrop - have been a customer for a while now and really appreciate all the effort you put. In particular, the fact you’re one of the only encrypted, cross platform note taking applications is amazing.
I’m really interested / impressed with where Roam and Obsidian have gone with note taking, in particular the backlinks function and the ‘daily note’. The backlinks/tagging makes it kind of incredible for interconnected notes, especially where you may not see the connection initially. Obsidian is based on local markdown files (a bit like Inkdrop, I think?). Roam is in the cloud. Neither have encryption.
Have you looked into a ‘linking’ function, like either of the above? I think they’d be crazy useful!
Thank you for your kind words and suggestion. I’m happy to know you like it.
That’d be a big change for Inkdrop and I need to understand how backlinks work and how people use them for their note-taking.
I checked out Obsidian and found that it has a dedicated large pane for backlinks.
As they say, it focuses on interconnecting your knowledge.
On the other hand, Inkdrop was meant to be an alternative to Evernote for programmers in the first place and I am basically happy with it.
So, there is a significant difference in concept between Inkdrop and Obsidian.
Supporting backlinks would require the app concept to be changed.
Besides, it looks similar to Evernote’s Context feature and I felt it’s great, but I rarely found it useful personally to be honest in the last few years as a premium user.
So, I think the feature strongly depends on personal preference.
In terms of UI, since Inkdrop focuses on its simplicity, adding more big features basically makes the UI more complicated and hard to use. As one user already complained that the desktop app UI looks noisy:
I kind of agree with him and would like to clean it up sometime soon.
So, at this point, I don’t feel like supporting backlinks.
But if you think adding it is simple and easy, you can create a plugin for it
A backlink pane is nice but not necessary for interconnecting. The main component is the ability to link notes by title, using [[note_name]] to link to note_name, as you’d do in wikipedia. If no there’s no existing note_name exists, clicking it in preview mode creates the note and redirects to it, so that the user can write his thoughts. If a note exists, the link text autocompletes with the possible note names, so that you can find the exact wording of your precedent notes.
Basically, it allows to connect notes much more instinctively. This is great as it allows non-linear notebooks without taking away the basic functionality of your product. It’s really the future of the market, I think : once you start to use an app allowing easy interlinks, it’s really hard to go back to classic notebook for your daily workflow/note-taking.
Thanks for letting me know your thoughts.
I understand the wiki-style linking would be useful for you and some people.
But Inkdrop is meant to be a Markdown note-taking app which should not break the compatibility with CommonMark in the first place.
Note-taking is like a private blog, but it looks like you want something like a private wiki.
The difference is completely based on a personal preference as we got a lot of similar apps out there.
If you really want it in Inkdrop, you can make a plugin for it, which does:
I am too interested in adding Roam-like functionality to inkdrop but I totally understand your explanation why this is not feasible for you. I really like the idea of adding plugins to Inkdrop to extend it with Roam features and whoever needs it can install it and use it. I have the following questions:
Is it possible to create a customized sidebar on the left-hand side that would allow displaying something similar to Roam sidebar?
Is it possible to use plugins in the mobile app?
Is it possible to create a plugin that offers shortcuts if I press a predefined key? like I am entering the / and it offers me all the shortcuts that Roam does?
Great to hear that you are interested in creating a plugin for this.
Yes, you can add custom panes:
Please read the documentation here:
Please read the Keymaps section in the plugin dev tutorial here:
How do I get it to parse the whole document correctly. I am guessing the existing link or linkReference parsing is interfering in some way. Here is my plugin so far (which was inspired by inkdrop-math):
Oh great! I would be happy to help you.
Maybe you can use remark-wiki-link instead of implementing it yourself.
Note that I’m planning to migrate the current markdown parser from remark to micromark in the near future.
Micromark is the new version of remark built by the same developer, which has a better extensibility.
Looks like remark-wiki-link already supports micromark in v1.x, but you have to use v0.x at the moment.
Hi Ryan,
Good to hear you make more progress.
That’s because Inkdrop renders it in React as you can see it uses rehype-react.
You have to override "a" tag behavior.
Great work! I installed the plugin and tried to create the links by just simply typing [[MyLink]] but when I am clicking on it nothing happens. What am I doing wrong here?
Of course, not. I tried with preview and it works as expected. Thank you. This is a great plugin.
I am not sure how hard to implement this, but it would be super nice if the created note would include all the documents that are linking to the current document. I think they call it reverse links in Roam.
That’d be expensive and pretty tricky (you’re scanning content of all notes, with a lot of notes, that might get pretty gnarly). It is not impossible though, but beyond that you would need somewhere to store that metadata on a note and I’m not sure if Inkdrop currently has arbitrary fields where we could put that.
My current priorities on the plugin are:
Figuring out if I can do anything for mobile (the current plugin uses db commands which do not work on mobile).
Adding autocomplete after the user types [[ to bring up a list of notes and then being able to tab complete note titles. @ebigram offered to help here, and he’s already done a great job with autocomplete on his emoji plugin.
After those, I’m not sure how much I would add to this specific plugin. But there could be other plugins used in conjunction with this that would do the reverse linking thing.
I just noticed some bugs with standard links. I did a bunch of cleanup and also switched to using span tags (instead of anchors). This fixed another bug where Inkdrop’s own link handling would cause an error because I was overriding behavior. They don’t need to be anchors anyway …
