Great work on the product, I’m loving it and will most definitely be paying for it once my trial is up!
I’m wondering if there are plans to allow customizing the theme on mobile. I’d love to be able to use Nord on all of my Inkdrop apps, instead of the regular dark mode currently supported on Android. I’d assume iOS is the same.
Thanks for the suggestion.
Theming on mobile is not supported, as it’s not possible to customize the whole UI with CSS because it’s built with React Native.
I understand you like Nord but it is not planned to be supported at the moment.
I need to find the best way for it.
