@craftzdog さん
いつも素敵なアプリをありがとうございます。
既にご認識済みでしたら恐縮ですが、
v6 において、sublime プラグインが動作しません。
結構、便利に使わせて頂いていたので、困っています。
こちらは、プラグイン自体のアップデート、あるいはv6に標準機能として組み込むなど、
なにか計画はございますか?
よろしければ、ご検討いただければ幸いです。よろしくお願い致します。
Thank you for the great app as always!
Apologies if you’re already aware of this, but the sublime plugin doesn’t work in v6.
I’ve been relying on it quite a bit, so this has been a bit of a problem for me.
Is there any plan to update the plugin itself, or perhaps incorporate similar keybindings as a built-in feature in v6?
I’d really appreciate it if you could consider this. Thank you for your time.
Best regards,
Ryuki
August 14, 2026, 2:39am
Hi @Ryuki_Yokoo ,
Unfortunately, CodeMirror 6 doesn’t have a Sublime Text keymap module.
Yes, the Sublime Text plugin is deprecated.
Which keymaps do you particularly use?
However, Inkdrop covers some of the equivalent commands to Sublime Text. Here is a coverage table:
sublime:*
v6 command
mac
linux / win
swap-line-up / swap-line-down
editor:move-line-up / editor:move-line-down
alt-up / alt-down
alt-up / alt-down
delete-line
editor:delete-line
cmd-d
ctrl-d
indent-less
editor:indent-less / editor:unindent
cmd-[ / shift-tab
ctrl-[ / shift-tab
del-line-right
editor:kill-line, editor:delete-wrapped-line-right
ctrl-k, cmd-delete
unbound
del-line-left
editor:delete-wrapped-line-left
cmd-backspace
unbound
add-cursor-to-prev-line / next-line
editor:select-lines-upward / editor:select-lines-downward
ctrl-shift-up / ctrl-shift-down
single-selection-top
editor:single-selection
escape
escape
transpose-chars
editor:transpose-chars
ctrl-t
unbound
smart-backspace
editor:delete-char-before (custom handler)
backspace
backspace
find-incremental
editor:find
cmd-f
ctrl-f
go-line-start-smart
editor:go-line-start — plain, not the toggling “smart” variant
cmd-left
home, alt-left
It doesn’t cover all the equivalent commands.
Could you tell me which commands are specifically necessary for you?
@craftzdog
Hi, thank you for the rapid reply!
The commands that are specifically necessary for me are below:
"ctrl-l": "sublime:select-line",
"ctrl-enter": "sublime:insert-line-after",
"ctrl-k ctrl-k": "sublime:del-line-right",
"shift-ctrl-up": "sublime:swap-line-up",
"shift-ctrl-down": "sublime:swap-line-down",
I appreciate your kind support!
Best regards,
Ryuki
August 15, 2026, 1:11am
Ryuki_Yokoo:
These three are already available as I mentioned in the table. You can bind them in your keymap.json like so:
".cm-editor .cm-scroller": {
"ctrl-k ctrl-k": "editor:kill-line",
"shift-ctrl-up": "editor:move-line-up",
"shift-ctrl-down": "editor:move-line-down"
See the doc page on key customizations:
I’ll add equivalent commands to sublime:select-line and sublime:insert-line-after.
Note that ctrl-enter is already taken by editor:edit-with-ai, which is the same keybinding as Zed.
Thanks for your feedback!
@craftzdog Thank you for the reply!
I understand! I’ll try setting up the keymap!
Also, thank you for considering adding the commands.
I’m looking forward to the update!
Hi @craftzdog ,
I have a quick question about the description on the List of commands page.
The description for the editor:kill-line command simply says “Deletes the line at the cursor,” which reads to me as if it deletes the entire line. Could you clarify whether it deletes the whole line, or only from the cursor to the end of the line (similar to Emacs’ traditional kill-line behavior)? I just want to make sure I’m binding the right command for my use case.
Thanks in advance!
Best regards,
Ryuki
August 18, 2026, 7:03am
7
Hi @Ryuki_Yokoo -san,
Yes, editor:kill-line works just as Emacs’.
Also, I just released v6.1.0, which includes a bunch of new editor commands covering Sublime Text actions.
And most importantly for you, I revived the sublime plugin as v1.0.0
Thanks again for your feedback
Hi @craftzdog ,
Thanks for confirming! That makes sense.
Since the description on the docs page could be misleading for others as well, I went ahead and opened a small PR to clarify it: https://github.com/inkdropapp/api-docs/pull/41
Also, thank you so much for releasing v6.1.0 and reviving the Sublime plugin — I really appreciate it. I’ll go try it out.
Thanks again for all your help throughout this thread.
Best regards,
Ryuki
