Snap with no visible letters in system dialogs on Fedora
When using the Snap on Fedora the system dialogs don’t pick a correct font resulting in just squares.
Here for example the Export dialog:
I tried to reset the font caches as mentioned in other threads like this:
But this all has sadly not corrected this problem.
  • Platform: Fedora 32
Hi Marco,
That’s strange and looks hard to investigate in my environment.
Do other Electron-based snap apps work correctly, like GitKraken?
I found a thread related to this issue:
Hi Takuya and thank you for having a look.
In this thread sadly they point to the user that they delete their font caches. Sadly this doesn’t work.
I also tried to delete the caches in ~/snap/inkdrop/common/.cache/fontconfig/
Also I tried to remove the configs from ~/snap/inkdrop/common/.config/fontconfig/ without success
For Chromium at least that I have installed as a snap the dialog boxes look okay there.
But oh I see you also have an .rpm to download. Then I will propably use this one.
But wait, it seems a general issue with Fedora and snaps - even the Snap Store app does not look good everywhere.
Here as screenshot when I want to remove the Chromium snap.
So the issue is likely not on your side :+1:
Looks like so.
Electron had the same issue but it’s been solved 3 years ago:
There might be a regression in the recent version but I couldn’t find that.
I suspect that it has something to do with your locale? Try changing the system language to en_US or something.
My locale is set to en_US. I’m looking through other Manjaro settings as recommended by the Arch wiki for anything that could be over riding it.
No success yet.
I had success with the following:
$ rm -f ./snap/inkdrop/common/.cache/fontconfig/*
$ rm -f ./snap/inkdrop/current/.cache/fontconfig/*
# this appears to be the key
$ snap run --shell inkdrop
$ fc-cache -r
$ exit
Let me know if this works for you
Thanks, @John_Kelley. I’ll give that a try in the morning. I had deleted and reinstalled fontconfig, but system wide, not within snap. This is a much more complete solution. I’ll report on my progress tomorrow.
@John_Kelley … that worked BEAUTIFULLY! The dialogue box now shows all the proper text. Thank you!!
That’s great news @Rich_Cook, I’m glad I could help!
Cool! Thank you, @John_Kelley.
I marked your post as a solution.
Cheers
