Hey there,
Is there a way to configure a shortcut to toggle wordwrapping natively inside of Inkdrop?
Hey there,
Hi Alex,
Yes, that’s possible by making a custom command and assigning a keymap to it.
First, create a custom command in your init.js like so:
inkdrop.commands.add(
document.body,
'custom:toggle-line-wrapping',
(event) => {
const lineWrapping = inkdrop.config.get('editor.lineWrapping')
inkdrop.config.set('editor.lineWrapping', !lineWrapping)
You can dispatch the command manually as follows:
inkdrop.commands.dispatch(document.body, 'custom:toggle-line-wrapping')
Assign a shortcut in your keymap.json:
".CodeMirror textarea": {
"ctrl-alt-l": "custom:toggle-line-wrapping"
Could this eventually be enabled in the application itself? If not, I’d imagine I could pretty easily turn this into a plugin.
I think it’d be nice to have a command like editor:toggle-line-wrapping and let you invoke it via the command palette, which is planned in the current roadmap.
This way, you don’t have to map shortcuts for every setting like Vim (:set wrap).
