Would you help suggest how to create a custom command and assign a keymap to toggle a readable line length ?
Your previous suggestion on line-wrap is helpful.
Thank you,
Bundit
Thank you,
Bundit
Hi Bundit,
Yes, you can do that by toggling the config value editor.limitMaxWidth
