Need Help with Sync Error in Inkdrop App
Hey there,
I have been using Inkdrop for a while now and it is been a fantastic tool for organizing my notes. However, I have encountered a bit of an issue recently that is been causing me some frustration.
Whenever I try to sync my notes across devices, I am getting an error message saying “Sync Failed” without any further details. I have tried restarting the app and checking my internet connection but the problem persists.
I also check this : https://forum.inkdrop.app/t/sync-error-notes-not-appearing-on-winformatica-bdm But I have not found any solution.
Has anyone else experienced this issue before? If so could you please share troubleshooting steps that might help me resolve it?
Hi Ben,
Have you run network diagnosis?
Also, please do not ignore the template. It is important to know your environment:
* [ ] I have checked [the troubleshooting](https://docs.inkdrop.app/manual/troubleshooting)
## Bug report
Write the description of the issue here.
If you got a problem, please check if you got any error in the console log by selecting the menu: `Developer -> Toggle Developer Tools`.
If you report an issue about a plugin, please check the author of the plugin:
* If it's a third-party plugin, report it on the GitHub Issue
* If it's an official plugin, report here
* Make sure you are using the latest version of the plugin. You can update it with `ipm update`.
### Environment <!-- DO NOT IGNORE -->
- Platform: <!-- macOS/Windows/Ubuntu/iOS/Android -->
- Platform version: <!-- Sonoma/11/20.04 -->
- App Version: <!-- Make sure you are using the LATEST version: https://forum.inkdrop.app/c/announcements/ -->
