When using multi-line cursor selections ctrl+shift+up
or ctrl+shift+down
the viewport only follows the cursor corretly one way. So when selecting multiple lines downwards the viewport correctly follows the cursor such that it is always in view, this does not happen when selecting upwards, see gif below.
- Platform: Windows
- Platform version: 11
- App Version: 5.4.3
- Have the cursor be on a line in a note document with more lines that can fit in view
- Press
ctrl+shift+down
enough times to reach a line that would have been out of view originally - See the viewport follow such that the cursor is still in view
- Go back to a single selected line/cursor
- Press
ctrl+shift+up
enough times to reach a line that would have been out of view originally - See the viewport incorrectly not follow the cursor such that you now can not see which line the cursor is on
