When I am writing with the vim plugin, inkdrop freezes frequently.
I don’t know how to reproduce the problem, but do you have any similar inquiries?
Platform: macOS
Platform version: Catalina/10/15.7
App Version: 5.5.1
I do not know the specific conditions.
It seems to happen often after pasting, but it also happens sometimes when editing normally.
However, waiting a few dozen seconds resolves it.
Thanks for the report. That’s weird.
I use it every day but I don’t have such an issue at the moment.
Do you mean you don’t get the issue without vim plugin?
Is that something to do with Japanese IME?
Thanks for the information.
I’m using Google Japanese Input but have never got such an issue so far.
Perhaps, it is related to this topic:
You mentioned that the app freezes after disabling Japanese IME.
So, I guess the IME would not be causing the issue. I don’t know at the moment.
Does it happen with Google IME?
Freezing with hjkl sounds weird.
They are just cursor motion operations, so nothing should block the UI.
If you found any ‘patterns’ to reproduce the issue, please let me know.
