Thank you guys for reporting issues!!
I’ve fixed a lot of weird behaviors and improved the new features.
New feature: Highlighting support with the <mark> tag
Highlighting text is one of the most popular use cases when you have reading notes.
As you may know, Inkdrop Web Clipper supports importing Kindle highlights.
With this update, Inkdrop works perfectly to emphasize what particularly resonates!
- To highlight with the
<mark>tag, select text:
- Click the highlight toolbar button:
- Now, it renders like so on the preview pane:
Here is a working demo:
The mobile app will also support it after releasing the desktop v6 officially. Stay tuned.
Refurbished the editor header bar
I wanted to make the UI more intuitive so people can use the app without having to read the documentation as much as possible.
This time, I added navigation and layout buttons that let you move forward and backward through the navigation history, as well as toggle distraction-free mode.
And I also added the editor view mode buttons:
These changes would significantly help new users understand the basic usage of the app.
Bug fixes
- fix(find-in-note): prevent toggling view mode for clear-find
- fix(editor): custom font-family not applied (Thanks @Lukas)
- fix(markdown-preview): missing
codetag in codeblocks insidepre - feat(mde): move focus to the title input from the top of the editor (Thanks Marco)
- Telescope search randomly stops (Thanks @Lukas)
- Telescope command search shows removed commands (Thanks @Lukas)
- Add
editor:move-line-upandeditor:move-line-down(Thanks @Lukas and TheRabidOstrich)- Keymaps: alt-up and alt-down
- fix(editor): display link tooltip for internal note links (Thanks @J_N)
- fix(preview): increase code block highlighting length limit to 1,000,000 (Thanks zyriab)
- fix(base-ui-theme): Incorrect menu background colors for the dark theme
ToDo
- Update Syntax & UI themes
- Syntax and UI theme preview
- Notebook icons
- Sidebar improvements
- Bundle Mermaid and Math by default
- Publish a separate
ipmcommand - AI features
- Preview pane improvements
- Find in preview (I finally came up with a promising idea)
- Improve image upload speed
- Arm64 support
- Migrate from leveldown to sqlite3
Join the Canary testing
[!warning]
macOS
Windows (x64)
Linux (x64)
There is our Discord server, where you can casually discuss and talk with other users.
