Hi! I’m thrilled to announce that Inkdrop v6.0.0-canary.16 now supports AI integrations.
AI Integrations
This release introduces a built-in Inline AI Assistant that lets you transform text right inside the editor.
- Select text and ask AI to rewrite it. Highlight any passage, open the inline prompt, and the result is applied in place.
- Built-in prompt presets to get you started quickly:
- Proofread your writing
- Summarize a passage
- Create a Mermaid diagram from a description
- Convert to a Markdown table
- …plus your own custom prompts.
- Bring your own API key. Configure your preferred AI provider in Preferences. Your keys are stored securely in your system credential storage.
AI features are opt-in and work with the provider and model you configure.
Check out the docs to learn how to set up AI and how to use the feature:
New features
- (macOS) “Look Up Selection” context menu: Right-click selected text to look it up using the macOS system dictionary/Look Up panel.
- Create a new note directly from [[ note-link autocomplete: Start typing a title after [[, and choose “Create new note” — the note is created, linked, and opened in one step.
- Open a new note in a separate window with a specific notebook: New notes opened in a separate window now respect the target notebook.
- Command:
core:new-note-in-separate-window - Shortcut key: cmd-shift-n / ctrl-shift-n
- Command:
Improvements
- Search bar in the Notebook Picker: Quickly filter notebooks by name in the dropdown — handy when you have a long list.
- Context menus for notebooks and tags: On the workspace header in the sidebar and on the note list header.
- Refined tooltip UI: The system tooltip was unstable, so I built a custom one for it.
Bug Fixes
- Crash on startup when the last-used tag no longer exists (thanks @shimizu_tatsuya).
- Notebooks created in a workspace get an incorrect parent notebook ID.
- (macOS) Cannot increase the editor font size after shrinking it to the minimum (thanks @Martin_Martinov).
- App hangs when triggering autocomplete with
[[. - Plugins are unexpectedly activated in the Preferences window (thanks @p1n9_d3v).
- Outdated plugins reload frequently in the Preferences window.
Community contributions - Claude Code Skills
I’d like to mention that Adrián shared his Claude Code skills that use Inkdrop as a persistance layer on our Discord server:
Let me quote his message:
Hey everyone!
I built a set of Claude Code skills that use Inkdrop as a persistence layer for AI-assisted dev workflows.
The idea: skills like
/to-prd,/to-issues,/journal, and/handoffsave state to Inkdrop across sessions using a four-notebook structure per project (Spec,Issues,Journal,Ideas) — so context survives even after a Claude Code session resets.Under the hood, note writing follows the
note-taking.mdrule that Takuya covered in one of his videosThe full pipeline:
/grill-me → clarify the idea /to-prd → structured PRD (saved to Spec) /to-issues → break it into slices (saved to Issues) /tdd → implement each slice /journal → log the session (what was done, what's next) /handoff → compact the session for the next agentAlso supports a Jira mode via
CLAUDE.local.mdfor work projects — PRDs and slices go to Jira, only the Journal stays in Inkdrop.Install with:
npx skills@latest add adrianfernandezalv/skills -y -gBased on Matt Pocock’s skills repo, adapted around Inkdrop.
https://github.com/adrianfernandezalv/skills
Happy to hear feedback!
Thank you so much for sharing amazing tips with us, @adrianfernandezalv!
Join the Canary testing
Warning
TODO
- AI: Next Edit Suggestions
- Update official themes
- Update manuals and API Docs
