Hey Inkdroppers,
Thank you for testing the beta version and reporting issues!
I hope this will be the final release candidate.
Bugfixes
- fix(preview): number of task list items not updated correctly (Thanks Lukas)
- fix(html): do not load
browser-commons.js(Thanks Lukas) - fix(share): The app crashes when sharing a note (Thanks Martin)
- fix(preferences): Add a note on the acrylic background effect on Windows
- fix(login): The login screen is broken
Join the beta testing
Donโt forget to configure backups before you test it!
Thank you so much for your support as always ![]()
