For Inkdrop and the vim plugin, what is proper way to rebind keys?
When I use vim, I never use esc to get out of insert mode. I normally use another key combination. For Inkdrop, I can’t figure out how to get this to work. I am trying to bind qq to get to normal mode. I have this in my keymap.cson file:
And I can even see the added key in the Keybindings in the preferences menu.
When I type qq in insert mode, it simply inserts the characters.
I have also tried other keys, such as ctrl-c and alt-c, and have had no luck. I have also tried putting these rules under the ".CodeMirror.vim-mode.normal-mode textarea" rules in tkeymap.cson.
Hi, in standard Vim Ctrl-[ works the same way as Escape. I’ve got this muscle memory as I use a MacBook Pro without a physical escape key. Can this mapping be added to the Vim plugin by default?
