Hi everyone!
Hope you’re all doing well. I’m getting back into using Inkdrop and ran into a bit of trouble trying to hide some inconvenient scrollbars — especially when using the sidetoc plugin and the readable line length option.
After some digging around with the help of Google and ChatGPT, I finally found a solution. I figured I’d organize everything here to share with the community — hope it helps!
On Windows and Linux
/* Hide vertical and horizontal scrollbars */
::-webkit-scrollbar {
width: 0px;
height: 0px;
/* Hide the scrollbar "thumb" (the draggable part) */
::-webkit-scrollbar-thumb {
background: transparent;
On MacOS
Read Takuya instructions on this post:
Can you please remove the vertical scroll bar? - Issues - Inkdrop Forum
I hope you find this tip useful! Have a nice day!
