Full Screen Button Disable Problem
  • Platform version: Sonoma 14.3.1
  • App Version: Version 5.8.0-beta.1
I updated the last beta version and after that as you can see there is a problem about close buttons. Only close button is active and the others disable. How can i resolve this problem?
Hi Tahsin,
Thanks for the report!
Looks like an Electron’s bug:
I’ll be updating Electron to fix it.
As a workaround, please edit config.json like so:
    "core": {
      "mainWindow": {
        "fullscreen": false  // <-- change this
Hi Takuya
Thank you for your answer. I resolved this problem with config.json
I’m gonna wait that you upload electron version :slight_smile:
Best regards
I’ll mark this topic as resolved when publishing a new version :slight_smile:
It should be fixed in v5.8.0-beta.2 :raised_hands:
Thanks again for reporting.
