Normally, after entering fullscreen, the two sidebars on the left will disappear and reappear after exiting fullscreen.
As seen on the screenshot, I have entered the fullscreen but nothing changed, and the UI for the sidebar became weird. I remember fullscreen was working before, but it isn’t after the recent app update. Also, I tried to disable all the plugins and the issue still exists so it has nothing to do with the plugins.
I gave it a try. Seems like I can enter and exit focus mode OK, but when the app is minimised to its narrowest window on iPad, I can’t open any notes. See video:
Also, there seems to be a strange delay when pressing Return on a hardware keyboard with iPad when the caret is on a blank new line. That delay isn’t present if text exists on the line. I don’t know if this is a new issue, but I don’t remember it from before
EDIT: This delay happens on the on-screen keyboard, too. And it happens on the App Store version on iOS, too, so I guess separate issue/enhancement
@J_N
As you reported in this topic, the app cannot detect the window size changes at the moment due to a bug in the framework. I’ll update it when the fix arrives.
Regarding the delay, I can’t reproduce it on my device or simulator. Can you create another topic for further investigation?
@Emily_Huang
Thanks for checking it!
It’s already published on the app store.
