Enable codefold
Not sure why this wouldn’t work :frowning:
require('codemirror/addon/fold/foldcode');
require('codemirror/addon/fold/foldgutter');
var cm = inkdrop.getActiveEditor().codeMirror;
cm.setOption('foldGutter', true);
cm.setOption('gutters', ['CodeMirror-foldgutter']);
Hi Samantha,
I guess you use the addons wrong way according to the demo: https://codemirror.net/demo/folding.html
The correct way would be:
require('codemirror/addon/fold/markdown-fold.js');
cm.setOption('gutters', ["CodeMirror-linenumbers", "CodeMirror-foldgutter"]);
And please don’t forget to load the addon/fold/foldgutter.css file.
Yey! ^ this is working, but then how can I fit it into the React structure? Got confused about what’s available and what’s not in Inkdrop …
Maybe worth adding those to the “Customizing the Editor” doc (or I can help once I know how to do it!)
Great!
You don’t need a React component for this use case because CodeMirror isn’t React-based component.
The spell checker plugin would be helpful to learn how to make a plugin that customizes the editor:
Yeah, adding such information to the documentation is nice!
I would appreciate your contribution :wink:
Did you make any changes to this in the latest update? It’s not working any more :frowning:
You have to run above every time you launch the app.
So I recommend you to make it as a plugin.
No I mean running the code above in the console right away doesn’t work anymore …
Did you load the CSS file?
You may have other problem because I checked that it works as expected on the current version.
I didn’t change anything regarding the editor in the last release, so it should work.
Kk, I tried again and yes putting it directly in the inspector still works.
Not sure why as a plugin it’s still not working :frowning:
I put it on a repo: https://github.com/moyicat/inkdrop-code-fold
Please describe me what’s going wrong such as errors you’ve got in detail as possible so that I can help you.
Okay, below code won’t work because unfortunately plugins can’t access to the app’s node_modules folder.
import foldCode from 'codemirror/addon/fold/foldcode'
import foldGutter from 'codemirror/addon/fold/foldgutter'
import foldMd from 'codemirror/addon/fold/markdown-fold.js'
So you have to include these files in your plugins.
Hope that helps.
Hey I tried to clean up the code a little bit as I don’t quite understand how babel works.
And I also included CodeMirror
However, it looks like the required() function is still not working.
When I console.log() from code-fold.js L23, the options are set correctly
consolelog
However, going into the generated HTML
You can see the HTML for .CodeMirror-linenumber are there, but .CodeMirror-foldmarker aren’t.
What should I change there to make it work?
Okay, I’ll look into it next week.
Thanks so much!
I looked into your code.
If you looked into the addons, you find that they require CodeMirror at <your_plugin>/node_modules/codemirror/lib/codemirror but they get a CodeMirror class object different from Inkdrop’s one because it is a module in a different path.
So the addons are being installed to another CodeMirror.
That’s why it doesn’t work.
A workaround would be to import the modules from the app’s node_module in order for the addons to use the same CodeMirror class object, like so:
const app = require('electron').remote.app;
const modulePath = app.getAppPath() + '/node_modules/'
require(modulePath + 'codemirror/addon/fold/foldcode.js');
require(modulePath + 'codemirror/addon/fold/foldgutter.js');
require(modulePath + 'codemirror/addon/fold/markdown-fold.js');
And please remove the dependency on ‘codemirror’ from your package.json.
I confirmed it works.
Hope that helps!
I documented this to the docs. Thanks!
https://doc.inkdrop.info/manual/customizing-the-editor
Yey! Made the changes and published it as a plugin! :muscle: Thanks so much!
Great!
https://app.inkdrop.info/plugins/code-fold
Could it have a screenshot in the description so that people can understand the plugin? :slight_smile:
Added :slight_smile:
Cool.
Thank you, Samantha!
Hey craftzdog,
I’m trying to improve the plugin by adding foldAll() and unfoldAll() functionalities, but I couldn’t get keymaps to work right: https://github.com/moyicat/inkdrop-code-fold/commit/7d88da28f90ceffd68555d916cc174581efd1e9b
What am I missing there? Can you help? Thanks!
