Check for Update
#1
I’d like a check for update function somewhere. Perhaps in the about window? I pressed later on the update dialog and now it has not shown up for 2 days forcing me to go the website myself. When does the dialog show itself again after choosing later?
Kind regards,
Sceptic
(Takuya Matsuyama) #2
Hi Sceptic,
Thank you for your suggestion and question.
On macOS and Windows, you only get the update dialog when the app is ready to update, having finished downloading the new version. So you don’t need to check manually for update again.
On Linux, it just notifies a new version available. It won’t show again until the next app launch if you pressed the later button.
I think it would be nice to describe about that on the update window.
(Yuko Otawara) #3
私も、更新ウィンドウで「Update Now」を選択してからダウンロードするものと勘違いしていました :sweat_smile:
更新データのダウンロードが完了した旨の説明と併せて、ボタン名も「Update Now」ではなく「Restart Now」の方が、具体的な動きが想像できて良いかもしれませんね。
(Takuya Matsuyama) #4
Yuko-san said, it would be nice to display “Restart Now” instead of “Update Now”.
Yeah, that’s good.
I guess “Update & Restart” would be better.
Thanks for the suggestion!
