Lukas
I noticed that in the latest beta version it is no longer possible to change the color of a tag.
- Platform: Windows
- Platform version: 11
- App Version: 5.6.0-beta.0
- Right click on a tag > “Tag Settings..”.
- Then you can select another color and click on save
- Now the dialog has closed, but the color is unchanged
Hi Lukas,
Thanks for the report. Yesss that’s a bug! Will be fixed in the next release.
Fixed in v5.6.0-beta.1! Thanks again for reporting
