Hello there,
I noticed that I cannot click nested checkboxes within the editor while the cursor is in the checkbox like:
* [ ] Level 1 * [ ] Level 2
Level 2 in this case is not clickable.
Hi Marco,
Thanks for the report. You are right - I found and fixed this bug while working on the new web app for sharing notes. This was due to the nested <label> HTML tags. So, it will be automatically solved in the new version!
<label>
