[Beta v5.6.3 Android] Note Conflicts while Editing
Similar to When I open a note separately, two notes don’t sync - Issues - Inkdrop Forum
Hi! I hope you enjoyed GW!
Thank you for the new beta release.
The launch-speed improvement is truly amazing!
As I wrote in the How to reproduce, conflicts are happening more frequently now.
If you need any additional information, feel free to ask.
  • Platform: Android (Xperia 10 IV)
  • Platform version: 14
  • App Version: v5.6.3(120)
  1. Open the note list
  2. Select a note and edit it
  3. Put the app to the background
  4. Play solitaire for a while :hot_beverage:
  5. Reopen the app and edit the same note you modified in Step 2.
  6. Return to the note list
video Step 1-4
1-4
video Step 5-6
5-6
Hi @Kinezi san,
Thanks for reporting, as always!
Yes, I’ve been experiencing the same issue on iOS as well.
I guess this is because the editing note state is not properly saved when its _rev changes. So, the app restores the old revision (the content is latest but _rev is still old).
Will push a fixed build!
I pushed build 122. Can you please check it?
I’ll be releasing it tomorrow hopefully.
v5.6.3 is out! Thanks again for reporting :smiley:
Sorry for late response. It works!! Thank you!
