API token is required when running `ipm publish`
API token is required when running ipm publish.
$ ipm publish minor
Welcome to Inkdrop!
Before you can publish packages, you'll need an API token.
Visit your account page on Inkdrop https://my.inkdrop.app/,
copy the token and paste it below when prompted.
Press [Enter] to open your account page on Inkdrop.
Access Key ID>
https://my.inkdrop.app/api-keys
I think this might be the same issue as #1536.
  • Platform version: Sequoia 15.5
  • App Version: 5.11.6
$ ipm publish minor
Hi Shimizu-san,
Ahh you are right. As of v5.11.5, the app no longer stores the access key in the keychain directly.
The ipm command will be provided as a separate CLI tool soon.
Sorry, could you please wait for it to be released?
I guess it should be next month hopefully.
It’s okay.
