I am using the default dark ui theme.
But, when I log in via remote desktop, the theme resets to default-light-ui.
The config.json has also changed.
Nothing is output to the console of the Developer Tool.
Is there a way to investigate the cause?
Platform: windows
Platform version: 10
App Version: 5.8.1 beta1
Boot Inkdrop.
logout and login via remote desktop
April 22, 2024, 6:57am
Hi Shimizu-san,
The app would respect the system theme mode setting if the Automatically toggle the default light / dark themes base on the system preferences option (core.toggleDarkThemeAutomatically) is enabled:
I donโt know if Remote Desktop would affect this setting though, can you please try disabling this option?
In the implementation, it is triggered by the nativeThemeโs โupdatedโ event:
Otherwise, it should not be changed automatically.
It has been improved.
We originally used the default light UI theme and switched to the dark UI theme at the timing of 5.8.1 beta1.
It may have been occurring from before.
ๅใๆฟใใใชใใใใซใชใใพใใใ
5.8.1 beta1 ใฎใฟใคใใณใฐใงใใผใฏใใผใใไฝฟใใใใซใชใฃใใฎใงใๅใใ็บ็ใใฆใใใฎใใใใใพใใใ
April 23, 2024, 1:23am
Great! So, it seems that the โupdatedโ event is unexpectedly fired when connecting via Remote Desktop.
