I’ve published another video tutorial, which is about the issue-driven tech note-taking workflow.
The text version is also available here:
Key points
- A simple rule: One note per issue
- You should focus on writing issues such as bugs, feature ideas, learning tasks, research topics, troubleshooting issues, and so on.
- Write both your understandings and misunderstandings
- It won’t help you learn by just copying & pasting the official documentation into your notes.
- Avoid striving for perfection
- Do not pretend to be smart in your notes
- Your notes are not homework reports to be submitted to your teacher
- Take notes while debugging, not afterwards
- Treat note-taking as a way to narrate your problem-solving journey to yourself, allowing for an objective view of the issues.
- Express your thoughts, including your emotions
- This way, even if you are working alone, it makes you feel like you are collaborating with yourself.
- Use note statuses to keep track of your issues
- With the ‘one note per issue’ approach, note statuses can let you manage your notes effectively as tasks.
Happy writing!
