The problem’s solved, after reboot the PC. somehow, I changed the username and password in the conf file, save it, and restart the inkdrop app, but it doesn’t take any effect, which I expected to.
Thanks for sharing curl way on checking the response. It guided me the auth is incorrect, then I checked the conf is correct as above mentioned, and I try to reboot the PC, it fixed.
