Version 2.1.6 describes itself as:
- fix (motion): Ignore numeric keys when a modifier key is pressed
However, this is preventing me from using commands like copying multiple lines. For example, when I type 5yy
I would expect the five lines from the cursor to be copied, but now only one goes into the buffer.
- Platform: Microsoft Windows 10 Pro
- Platform version: 10.0.19042 Build 19042
- App Version: 5.1.2
- Plugin Version: 2.1.6
Use any command starting with a number and the behavior will be as if no number was entered.
