Vim keybinding setup
Attempting to set the vim keybindings manually up from the branch https://github.com/inkdropapp/inkdrop-vim/tree/v6 to ~/Library/Application Support/inkdrop-canary/packages/vim results in the following error. Could you provide some suggestions on how to resolve this?
  • Platform version: Sequoia 15.6
  • App Version: 6.0.0-canary.1
Thank you
Hi @Bundit_Jianpinitnan !
You can install the vim plugin for v6 by following these steps:
  1. Clone the v6 branch of the repos in ~/Library/Application Support/inkdrop-canary/dev/packages/vim
  2. cd to the cloned folder
  3. Run npm i --omit=dev to install dependencies
Reload Inkdrop
It works. Thank you for your swift response.
With the new IPM command finally available, you can now install vim@3.0.0 via the plugin registry! :raised_hands:
You can remove the folder ~/Library/Application Support/inkdrop-canary/dev/packages/vim and install it again as usual.
