Vibrant Dark UI Theme Problem
Hi, I really appreciate your great work!
However, It seems that Vibrant Dark UI Theme does not work on my environment (see the attached screen shot).
I first gave a suspicious look at macOS Mojave’s dark mode, but it still does not work with light mode.
Can you take a look at this problem? Thank you.
  • Platform version: Mojave 10.14
  • App Version: (3.22.4)
  • Plugin Version: Vibrant Dark UI 0.2.4
$ ipm install vibrant-dark-ui
Then, set the UI theme from Preferences
Hi Kosuke,
Thank you for the report.
It is duplicate of Vibrant dark ui rendering issue.
I’m working on it.
I see, thank you :smile:
I have the same problem with Vibrant Dark UI Theme as above. It works fine in dark mode but not in light mode.
  • Platform version: Monterey 12.5.1
  • App Version: (5.5.1)
  • Plugin Version: Vibrant Dark UI 1.3.2
Vibrant Dark UI Theme is only for dark mode. It doesn’t work in light mode by design.
