Uncaught (in promise) Error: Cannot find module ‘’
Require stack:
- /Users/patsmith/Library/Application Support/inkdrop/packages/move-notes/lib/inkdrop-move-notes.js
- /Applications/Inkdrop.app/Contents/Resources/app.asar/index.html
at Module._resolveFilename (/Applications/Inkdro…s/cjs/loader.js:887)
at Function.o._resolveFilename (/Applications/Inkdro…renderer_init.js:33)
at Module._load (/Applications/Inkdro…s/cjs/loader.js:732)
at Function.f._load (/Applications/Inkdro…2c/asar_bundle.js:5)
at Function.o._load (/Applications/Inkdro…renderer_init.js:33)
at Module.e.require (/Applications/Inkdro…r/browser-main.js:4)
at require (/Applications/Inkdro…s/cjs/helpers.js:88)
at loadConfig (/Applications/Inkdro…rop-move-notes.js:9)
at Object.activate (/Applications/Inkdro…op-move-notes.js:67)
at t.default.activateNow (/Applications/Inkdro…r/browser-main.js:1)
at /Applications/Inkdro…r/browser-main.js:1
at t.default.measure (/Applications/Inkdro…r/browser-main.js:1)
at new Promise ()
at t.default.activate (/Applications/Inkdro…r/browser-main.js:1)
at e.exports.activatePackage (/Applications/Inkdro…r/browser-main.js:4)
at /Applications/Inkdro…r/browser-main.js:4
at e.transactAsync (/Applications/Inkdro…r/browser-main.js:4)
at e.exports.activatePackages (/Applications/Inkdro…r/browser-main.js:4)
at e.exports.activate (/Applications/Inkdro…r/browser-main.js:4)
at t.Z.activatePlugins (/Applications/Inkdro…r/browser-main.js:1)
at s.componentDidMount (/Applications/Inkdro…r/browser-main.js:1)
at Ji (/Applications/Inkdro…oduction.min.js:212)
at Sj (/Applications/Inkdro…oduction.min.js:255)
at exports.unstable_runWithPriority (/Applications/Inkdro…roduction.min.js:19)
at cg (/Applications/Inkdro…oduction.min.js:122)
at Jj (/Applications/Inkdro…oduction.min.js:248)
at yj (/Applications/Inkdro…oduction.min.js:239)
at /Applications/Inkdro…oduction.min.js:123
Write the description of the issue here.
If you got a problem, please check if you got any error in the console log by selecting the menu: Developer -> Toggle Developer Tools.
If you report an issue about a plugin, please check the author of the plugin:
- If it’s a third-party plugin, report it on the GitHub Issue
- If it’s an official plugin, report here
- Make sure you are using the latest version of the plugin. You can update it with
ipm update.
- Platform: (macOS/Windows/Ubuntu/iOS/Android)
- Platform version: (Mojave/10/16.04)
- App Version: (4.3.0)
Write the steps for others to reproduce issue here.
