Unable to upload photo on iOS
@anon74459912
Thanks for testing it and the report.
Hmm, yeah, that’s super weird.
I think adding an image from another client has nothing to do with this issue in terms of implementation.
Maybe it could be an iOS bug or something.
I’ll revert the change of asking for permissions for now.
Thanks again for your report!
Sure. I will report, when I see it again or have an idea what caused it.
Okay!
Works great here! That fixed it.
@Ryan_McQuen Thanks for testing! Does it work if reinstalled the version from the AppStore now, like @anon74459912?
Nope, same issue as before.
Thanks for checking it. Oh, really.
Okay, it’d be good to report to the library.
Update: Good news - A PR for supporting PHPickerViewController is being reviewed!
I’ll update it once merged.
Yeah, that is related to the original GitHub issue I posted.
I still have this problem.
The app freeze after I try to insert an image from photo library
App version: 4.1, 4.1.1 (I tried both app-store and test-flight version)
Device: iPhone 12
iOS version: 14.4.2
I’ll update the image picker module once it supports PHPickerViewController.
I still don’t know if it solves the issue though.
The PR for supporting PHPickerViewController has been merged:
I’ll update it.
I’ve published a beta build that uses PHPickerViewController.
It should solve the issue @anon94201665 reported.
Can you guys please try it?
It works! :tada::tada::tada:
@Ryan_McQuen Finally :laughing: Thanks for checking!
v4.2.0 is out🎉 Thanks again for the feedback XD
Credited you guys:
