Hey
Iām currently unable to log on using my work computer. Itās a banking laptop, so there probably are some software shenanigans going on in the background that might interfere with Inkdrop. The demo version of Inkdrop works perfectly well, which is why I wanted to subscribe to Inkdrop
Itās a Windows 10 laptop. When I log on while on the companyās VPN, I get the following error:
Error message:
getaddrinfo ENOTFOUND http://api.inkdrop.app Please check your system configuration or report the problem.
Status code:
We use PulseSecureās MyRAS VPN, for what its worth.
When Iām not on VPN, I get this error:
Error message:
connect EACCES 54.157.4.65:443 Please check your system configuration or report the problem.
Status code:
The IT team says they do not support non-endorsed programs and applications, so they werenāt able to help me with this.
Is there anyone who encountered these errors before, and do you know how I get around it?
Thanks
