UI Problem For Left Side
  • Platform version: Sonoma 14.6.1
  • App Version: Version 5.9.0-beta.0 (5.9.0-beta.0)
If you see the image, If you add image in description area, There is a ui problem. How can i resolve this problem?
Looks like it’s a bug of the thubnail-list plugin by @yk4to . Can you look into it?
This looks like a problem with multiple-thumbnail-list-and-short-date, which is a fork of my plugin.
It has been forked from an outdated version of thumbnail-list, so probably needs to be updated.
@ryanlutgen Can you check this please?
Ah, after upgrading Inkdrop to v5.9.0-beta.0, even the original thumbnail-list plugin looks odd.
It sounds like an upstream issue. I’ll fix it later.
2024-09-30 at 13.25.35@2x
After some digging, I found that it was caused by another plugin I made, hide-front-matter.
Looks like the “summary” class was missing from the NoteListItemSummaryView.
I’ve already published a patch for that.
@cagrizorkol, please let me know if the problem was fixed after updating plugins.
It was fixed with your new version. Thank u so much @yk4to ! :slight_smile:
Awesome work, as always, @yk4to :clap:
