What steps should I take to transfer the repository for a plugin to my new GitHub account since I’ve created a new personal account on GitHub that I primarily use?
Plugins are tied to your Inkdrop account, not your GitHub account.
But the repository paths have to be updated manually.
Can you tell me your plugins and destination repositories?
Thank you for your reply.
Plugin URL: Inkdrop - Organizing Markdown notes made simple
Previous repository: GitHub - bildeneins/character-count: An Inkdrop plugin that provides a function to count the number of characters and words
Destination repository: GitHub - jajimajp/character-count: An Inkdrop plugin that provides a function to count the number of characters and words
Got it. I’ve updated the repository path.
Next, please update the repository field of package.json: character-count/package.json at main · jajimajp/character-count · GitHub
Then, you should be good to go.
I got it. I have corrected the field.
@craftzdog
The repository URL has been updated on the web plugin page, but it seems that the URL remains unchanged when searching the plugin within the application’s environment settings. Is it possible to fix this?
okay, updated!
confirmed! thank you.
