TOC links don't jump
The TOC Plugin creates the toc, but the links are not functional.
  • Platform: Windows
  • Platform version: 10
  • Inkdrop Version: 3.23.1
  • TOC Plugin Version: 2.0.4 (ipm view toc)
  • Install the TOC plugin.
  • Create a new note with some headings with enough text, so you have to scroll.
  • Add #### toc at the top of the note. The table of contents should be created now.
  • Click on a toc-link, but it will not jump to the correspondent heading.
kind regards
Hi Nicolo,
Thank you for the report!
That’s a bug due to the recent change in the renderer for supporting stable inline HTML.
Next version will fix this.
v3.23.2 should fix the problem. Thanks again for the report!
TOC works again as expected. Thanks a lot!
