Terminal Commands
I may make a plugin for this if possible but i wanted to see if anyone has gotten a terminal window from within the inkdrop interface.
here is an example of a terminal within an atom app:
most of the code is there i just dont know if inkdrop can have new windows.
thanks
Thank you for the question.
I’m happy to help you make a plugin!
Yes, you can add a component at the bottom of the editor like so:
inkdrop.components.registerClass(YOUR_REACT_COMPONENT)
const editorLayout = inkdrop.layouts.getLayout('editor') // -> ['EditorTitleBar', 'EditorMetaForm', 'MDEContainer', 'EditorSearchBox']
editorLayout.push('YOUR_REACT_COMPONENT')
inkdrop.layouts.defineLayout('editor', editorLayout)
Hope it’s helpful.
Related topic:
