Telescope result selection influenced by mouse
When searching for a command in Telescope, sometimes a search result is selected with the mouse even though the mouse is not being moved. I would expect that the mouse pointer would have no effect on the selection of a search result if it is not being moved. By default, the first result should be selected.
This usually works, but sometimes it doesn’t. I can’t see a pattern behind it.
  • Platform: Windows
  • Platform version: 11
  • App Version: 6.0.0-canary.1
See for yourself:
telescope-result-selection
Hi @Lukas,
It looks like the event should be mousemove instead of mouseenter here. Will update it!
Fixed it in Canary.2. Thanks for the feedback!
