Telescope alignment/positioning
First, it’s a great feature. I am already using it frequently. I quite like it. It really makes navigating notes easier. It also makes using rarely used commands easier.
However, I find it a bit distracting that the text input field constantly moves as the number of search results changes. It would be great if the text input field always stayed in the same position.
good point, @Lukas .
and I’m glad you enjoy it!
agree, the top position should be fixed.
Fixed it in Canary.2. Thanks for the feedback!
