When you click on Settings icon → Sync → Advanced (Sync with own server) and input a URL → hit Approve and close the window → this will trigger a sync and status down there changes to Syncing.
After a while it shows Synced and I thought it did happen and all is okay. But when I tried it locally to reach my db server it appeared I did not expose the right port, but the App says all is fine “I am synced”. Instead if the backend call ends with an error (which I found out later by using “Run network diagnosis” app shall show correct state, something like “Synchronisation unsuccessful” with some red cross icon but this currently does not happen.
- Platform: macOS
- Platform version: Sonoma 14.3.1
- App Version: 5.8.0 latest
Announcements - Inkdrop Forum →
As stated in the Bug report → just select advanced in settings and input invalid URL.
